waterboy
Cherbourg 22nd July, 9.00 ish. First alerted by shrill female voice shouting "slow down". Saw mast moving fast between P and Q pontoons. Then without any discernable slowing, said mast did a sharp turn to left into a vacant berth. Bouncing off the boat to right just behind the end of the finger pontoon, then the boat to left in same finger pontoon bay, the still fast moving boat, now completely in view, hit the main walkway. Luckily the boat was an older design, one with a shallow pitched curved stem instead of the modern near vertical design. The boat rose up over the walkway and slid across aiming directly at a sideways moored Contest on the other side. Stopped by its keel, inches short of the Contest, the boat slid back into the water with surprisingly little damage. Apparently, the throttle lever stuck. Ironically, across the transom .... RAFYC.
