HOTPOINT HEATER.....any good?
I would think that the problem is that you only get heat when the engine is running and shortly after. (my commnet is not specific to this heater). I would think it far better to be able to heat a calorifier insulated tank then be able to pump hot water around for heating when you want it and hopefully lasting a lot longer after engine shut down. (and of course usable on shore power). But then what would I know. Hae never dreamed of fitting a boat heater. (Aircon maybe) olewill
You will need a decent sized motor to supply enough waste heat for that beast to work at any efficiency at all, I would suspect the usual yacht little auxiliary motor would not cut the mustard by quite a margin. It's basically a coach heater.
An American sailor I know has a very novel means of heating his saloon, he is a liveaboard on the Inland Waterway.
He used ceramic flower pots over a heat source, even night lights he says work ok, he also adds several on top of each other when needed over a small gas cooker flame, he claims it is very cosy, no need for sweaters, and it does get cold where he is.
I presume that it wroks only on dull winter days
Hugely effective - those tea light candles give out about 20 watts of heat! Enough to generate sub-tropical temperatures, no doubt! For a more balanced view, see http://www.ybw.com/forums/showthread.php?336399-hot-boat-hot-office-for-8p-a-day
Not that particular brand but similar ones (it's only a matrix and very power hungry fans), please advise what you intend to use as a hot water supply for it and I can give you a better answer. Just consider what you have to put into it to get the claimed 10,000w output.
The intention is to use it only when the engine (35HP) is running and use the engine indirect cooling water which is also shared with the calorifier.
I note that there are three fan speeds so 10KW would only be used occassionaly. I realise management would be involved in striking a balance between the domestic hot water needs and the heating requirements.
It seems a good way of getting a heating system into a wooden boat where there is no chance of locating an Eber or the like.
Thanks for useful comments thus far
