sailorman
Why ?
This outcome, just as well the OP found them b 4 worst happened
Why ?
3 yrs is not long for a house or starter battery. Do they have a warranty?
The reason is that if you leave a powerful mains charger connected when you leave the boat it can easily overheat a failing battery. Such a battery might distort and bulge, or even split leaking out its remaining acid. A low wattage solar system giving enough charge to maintain good batteries will not have enough power to boil up bad ones, so it is safe. I have 100 watts worth of solar panels, which is enough to maintain four 105AH batteries.
I would then reconsider my charging regime, connect a solar or wind & leave the mains charger off when unattended :encouragement:
