Hose Fitting ID
Dino
27 Apr 2009
Ireland
Hi,
I bought a Broom Crown recently and it has a deck wash pump fitted to the port engine and the attached hose fitting at the upper helm position. Does anyone know what type of fitting this is and where I might get something to fit it.
Thanks!
Dino
You need to measure the pitch and diameters of the thread, and then the TPI to establish if it is BSP or metric, and which type.
It will have a threaded end but that will not help with connection size, measure the ID of the outlet and this will give an idea of the connection size, then order a couple close to this to try, they are cheap enough.
You can download the cam lock fittings catalogue which has all the dimensions and options so google will show you all you need to know, no need to guess when the info is all there.
