vas
OK, I admit that this must be silliest of my refit queries, but here it goes
About to restore my twin horn setup which looks dangerously similar to these:
http://www.vetus-shop.com/vetus-double-trumpet-horn-24v-high-pitch-andamp-low-pitch-p-1586.html
Checking at the Z shaped support with it's two securing holes, I wonder if one is meant to have the 45cm long horn supported on the two screws and keep the end of the horn on the air or bend the Z support a bit so that when fully bolted the end of the horn touches the flat surface it's bolted on.
Horns will fit in the coachroof in a spot that none is normally going to reach/mess about. Horns will be slanted around 10deg downwards so water is not going to remain in them (hopefully)
What does the panel think?
I feel that the supports will let the horns (especially the longer one) vibrate and eventually touch/mess with the coachroof.
Mind atm if I tighten the bolts properly, the end of the horn is level with the mounting surface.
Any ideas?
JFM is not allowed to suggest I buy a K-380 Kahlenberg or something similar cause it's not going to happen - and it's not a space issue got plenty of space for the compressor
cheers
V.
Any ideas?
cheers
V.
