Jaguar 25
When I was removing the outboard from my boat, stupidly I disconnected the positive terminal at the outboard before disconnecting it at the battery. The inevitable happened and as I pulled the lead out, it shorted against the engine casting. Now the engine will not start having always been a first time starter.
I have checked the fuses that I can see and they are OK. Presumably something in the ignition circuit has blown.
I would appreciate any ideas as to what the fault is likely to be and how to fix it?
It is Honda model number HZ BF8 DLRU, built in 2012.
