banflu1
Active Member
So yesterday I used Liqui moly engine flush plus on the port engine. First I let it reach 150F, turned it off, added the flush, then let it idle for 15 mins.
I drained it immediately, replaced the filter once again and refilled with the same oil (Fuchs truck plus 15w40 vds-3).
After that I went for a test run.
After the engine is hot (175F), the oil pressure varies from ~40 psi at idle to ~85 psi at full throttle.
It is all within spec so I’m not overly concerned, however, the other engine doesn’t go over 65/70 psi even at WOT when hot. So something must have happened to cause this change.
There is still a minor oil leak below the engine / back side, and my mechanic should try and find it’s cause next week.
