High gloss varnish
Tucepi
13 Oct 2001
Eastbourne
I have just bought a Birchwood TS31 in need of some TLC. The interior wood is dull and in need of some fresh varnish. Can anyone recommend a high gloss finish varnish, and where it can be purchased from. I have read in the MBM magazine last month someone using "Two Pack epoxy varnish" what is it and is it any good. Appreciate the advice from you experts as I am a novice.
BarryH
31 Oct 2001
Surrey
If its for the interior you cant beat Japlac clear, its a highgloss laquer without the smell of polyurethane, the two pack sysrems are hard wearing but are slightly harder to apply, or if you have a screw-fix booklet, they do polyurethane in a spraycan which gives a great finish. Ive used Japlac on the cabin joinery in my boat it still looks good after 5 years. It doesnt mark and really brings out the grain of the timber. Its sold in most DIY stores and will be found around the International paint stand. The coloured laquers are very similar to Internationals Toplac. hope this helps, just remember prep is 90% of the job Good luck
DepSol
6 Oct 2001
Guernsey
I use Decks oil (deksoyle) on all my wood, lots of applications and it comes out looking lovely.
Up to you.
Dave_Snelson
16 Oct 2001
Porthmadog / Port Leucate
Two-pack epoxy from International is very good and very expensive, great for exterior work. For interior work the Japlac (also International) mentioned below is right for the job.
Remember, you want to take the stuff off again one day!!
Good Luck
