Seajet
Zebedeeoneil,
unless I missed it, where do you plan to keep and sail her ?
Managed to get the pictures uploaded, didt get as much as wanted done today but all the same its progress, in one the pictures theirs a red tube coming out the engine block and I haven't got a clue what it Is, the gearbox oil looks new just the battrey was nearly dead so gota recharge it before Saturday when next go down their , I'm planing on keeping her at ports solent by mother kellys and sail it in the harbour untill I get used to sailing lol
ThatS my next job I had the engine turn over but theirs no petrol in her tanks until the weekend(is it 25/1 mix with oil?) Wheir a bouts is the seawater inlet, is it the red hose next to the gear lever? Also im going to try align the shaft its nearly their,is it something I can do myself or do I need a machanic? Thanks in advance
I owned a Snapdragon with a Vire 7 for several years. I replaced mains, big-end, (which is a "special"), and crankshaft-seals. V. easy to work on.
Petrol power isn't my favourite of course, but it gave very little trouble during my ownership, and could be hand-started readily, it's important to keep contact breaker points in good order.
An oiled plug was very unusual, unlike a pal's Stuart-Turner!
Fuel consumption was generally reasonable unless you wound the throttle well open, when it became horrendous.
IIRC, the battery charging output was fairly pathetic.
But you would need a starter motor as well.The oiled plugs incident I remember so well was on a Stuart Turner, I just assumed that a Vire, being 2/, would be as bad, glad to hear they aren't!
Pathetic battery charging is likely to be due to it having a dynamo (or even a Dynastart) rather than an alternator. Should be easy enough to switch from dynamo to alternator on a boat.
Thanks for all the reply, I've removed the shelter from the rear (looks alot better)
Will be removing the pallet 2morw rain stopd play lol. Are you able to lower the mast on these boats?
