Refueler
I have two Mk V's on board .... one does the engine bay - other does the shaft area ...
The Engine bay pump even after 30 odd years still pumps like a good-un ...
The shaft area one is ????
So decided to remove and have a look ...
Taking apart - I find 4 M5 screws ... 2 self tappers .... 3 washers and 3 nuts - that fit the M5's .... all sitting in the pump chamber. Again this pump is over 30yrs old and all good ... both valves good ... diaphragm good ...
What I found was something that is quite common ... a short piece of pipe to fit pump - then a slightly smaller diameter pipe to suction pushed into that short pipe and tape-sealed.
Clean it all up ... (of course emptied the screws etc !) ... retaped / joined pipework .....
NOW it pumps !! But obviously the suction end of pipe has something ... so will need lift cockpit sole later and have a gander at that ...
Reckon 30 odd yrs is not bad ... diaphragm and valves are still supple ...
