HELP ....
  • Start date Start date
G
Guest
Guest
My dear old Perkins 4-99 has a Glow plug cold start insert in the air-intake that has a diesel feed to it. When energised the valve allows a small drip of diesel onto the glow element and it 'catches fire' - this flame gest sucked into the engine and away it goes ! Sounds 'orrible ... but true and works a treat ..... till the valve got blocked !
The previous owner never fitted the diesel reservoir to use it and disconnected the wiring. So I temporarily fitted a piece of 3/8 plastic pipe to the inlet stem and filled it with diesel. Connected the wires to a switch and presto it worked.... until I left the switch ON and the plug got too hot, melted the pipe and a bit of of plastic got stuck in the valve. Now it glows but no fuel goes through !!!!!
Has anyone any idea how I can remove the blockage ? I've tried to remove with a pin etc. but no luck. The plug cannot be dismantled etc. etc. only removed intact from the intake.
has anyone a glow plug of this type spare / lieing around their garage / workshop that I could have ??
Finally can anyone give me a diesel engine wiring diagram based on an average set-up ...... twin battery, alternator charged via 1-B-2-Off switch .... as the prat who wired mine up has the Alternator light permanently aglow !!!!
Sorry, can't help regarding the glow plug problem but for the wiring diagram go to www.adverc.com - they do battery controllers and I'm sure they show 2 or 3 wiring diagram.
dickh
I'd rather be sailing...
Dissolve it out
Depends upon the type of tubing but few will resist acetone for long. Cellulose thinners is a mixture of solvents that probably contains various acetates and toluene. This may be the best that can be purchased for this job by the amateur. I thought you were laboratory-based, Nigel. Can you get something a little stronger?
Re: Dissolve it out
I've tried all sorts of 'crap' to get it out, but the plastic actually got that hot that it literally carbonised !!!!
I will try some 'orrible potions in my arsenal, but was reluctant to do it as I do not want to corrode / attack the element !!
The plastic in question is standard blue-clear garden variety 3/8 pipe. So the solvent will work, but also I would assume that the valve must be operating to allow the solvent to 'pass through' .... which now brings us to a delicate situation ..... the glow plug gets bl--- hot to activate the valve ... so literally could cause a small fire with the solvent !
Adverc wiring diagrams are v. basic and don't show the wiring for the alternator charging light. Suggest try contacting Sabre Engines whom I have found very helpful in the past. They provided me with the engine wiring diagram for a 4.236M.
you can get a new one from lucas, it's called a thermostart, i remember these fitted to markhandler forklifts fitted with perkins engines. as i recall these were fitted with a diesel supply straight from the lift pump and only opened when hot, when working it works a treat. hope this helps.
<A target="_blank" HREF=http://homepage.ntlworld.com/s.amos/index.html>http://homepage.ntlworld.com/s.amos/index.html</A>
It works absolutely great .... OK some are a little frightened that it oftens ignites the fuel with a loud POP and smoke trickles out of the air-intake ..... but I can say that the engine for many years was started on Easy-start and I thought and many agreed - including engineers that probably it would need ES for the rest of its life .... but no, a dribble of diesel onto the plug and it fired up first turn ! Amazing.
Now all I have to do is get the old one clear of the plastic or buy another one !! My 4-99 is the older type that has feed from a small reservoir supposed to 7 - 12" above the intake. Later models were fed from the 'return-line' to the tank.
I fitted a length of 3/8 plastic pipe to act as the reservoir ... fine till I left the plug on for over an hour !!! melted the pipe and blocked the minute valve hole !!!!!
Anyway - thanks all.
