IanC
Can anyone give me a list of things I should look at to try and solve a problem with one of my Volvo AQ140 petrol engines. Here's the situation: - it starts OK and will rev when not in gear. When in gear and cruising it will do OK at slowish speeds, but when you open her up the engine dies back - it's like it looses all power and will even stall when you are accelerating. You can then start it again without too much difficulty. When this problem happens - you can 'punch' the accelerator and can get the revs up and she will do OK. There is nothing around the Prop - the temperature gauge shows normal - there's plenty of petrol in the tank - what could it be? Any ideas of a hit-list to look at would be really welcome.
thanks so much
Ian C.
thanks so much
Ian C.
