Crinan12
Hi all
Issue with nasa depth sounder - was hoping someone could help.
It often gives totally wrong readings. I.e display says 10 metres when we are in 100 metres of water.
However in shallower water it seems fine. When on our mooring it gives the correct depth and the reading changes with the rise and fall of the tide and it seems quite happy.
I've taken out the transducer thing from the tube that is fitted on the hull but there isn't really much to look at. There is oil in the tube but only a little bit - maybe a cm. Should the tube be fill of oil?
Any thoughts would be appreciated
Douglas
Douglas
