It's a split charge diode, the input is connected to the input terminal of the Argo. it's possibly there to charge a battery at the bow for the windlass or bow thruster ?
If it is and i was the OP, i'd replace it, and the Argo, with a 3 output Argofet, neater, tidier and less voltage drop.
Thanks Paul. Does below look OK to you?:
Yes there is both a bow thruster and windlass
Thanks Paul, really appreciate it.
Is there any particular kind of busbar you'd recommend?
Brilliant, thank you. Going to measure up tomorrow and then order wiring and busbar etc. Once I have the BMV installed next up is 2x170 watt semi flexible solar panels and a Victron MPP!You have a few heavy cables there, so i'd use something like this: Busbar, Black Power Distribution Point, 210 Amp, 1 Post
