tobiasg
Hi all,
I'm looking at cleaning up the electrics on my new boat and want to have some extra eyes on my proposed setup. I'm pretty new to boating so forgive my if I'm asking stupid questions or lack some of the correct terminology.
Here's the setup:
Hope the above intensions make sense and would love to have people throw stones at it.
I know the Amps (thus fuse size) I need for my GPS/fish finder from the manual but I know I need to figure out the fuse sizes for my other electronics still, then have cables correctly sized (rated more than the fuses) based on that.
I guess the main questions I have are:
Here's the setup:
- I have a single battery (it's a small boat so no fancy starter and deep cycle setup as I only plan to run a few small electronics of it)
- I have a isolator switch right after the battery to turn everything off
- After the isolator switch I have the positive go to the engine and the other way a fuse to protect the rest of the circuit
- Next + buss bar leading to switch panel, fuses then lights/bilge pump
- GPS/Fishfinder does no go through the switch panel as it has its own on/off switch
- The bilge pump sensor leading again to the bilge pump is not behind the isolator switch so it will run even if electrics are tuned off
- Finally everything leads back to the - buss bar and back to the battery
- Is the above ok?
- Am i right in not putting a fuse for engine starter?
- For battery to engine what gauge cable should I use?
- Should the negative from the engine go through the - buss bar or can it just go straight back to the battery?
- Any other tips/suggestions also welcome
