niallw70
Active Member
I have a rebuilt Yanmar 1gm10. Since overhaul starts ok but the charge light staying on when engine tested.
Im confused about how alternator is wired up, or how to test voltage/ current output in confined space of engine bay.
At rear of alternator there are 4 posts for spade or ring cable cable terminations. Also there is three pin socket with pins labelled E, earth?, F, N. The mating plug goes to an external voltage regulator. VR manufacturer NIPPONDENSO, serial no 0260003861.
There are zero markings or serial model/ numbers on the casing of the alternator itself.
Is this a standard Yanmar alternator?
35 or 55A? How should this thing be wired up? No markings of any kind to indicate +,-, Excitation on the back of the alternator.
I will try supplying a photo in this post. Ive had problems with uploading pictures before to this forum. What camera settings should i use? Even on lowest quality pixels, the attachment rejected.
