Help needed. Where does the earth one go?
steveeasy
12 Aug 2014
Ok some months ago I disconnected the supply from my 12 both switch to my switch panal.
I’ve retired everything to a switch panel and went to reconnect the supply cable from the 1-2 both switch to panel and quite frankly can’t remember where the earth cable goes.
I know where the positive wire goes but have no idea where to connect the earth. Here’s some pics
steveeasy
12 Aug 2014
Yes 12v black.
From memory I cut the red positive wire from 1-2 both switch to isolate panal. Gone to reconnect it and trying to work out where I run an earth from panel too?
Steveeasy
steveeasy
12 Aug 2014
Only the Positive cables are wired through the 1B2 switch.
Yes I understand that. I am trying to remember/ understand where to run earth too.
I’m guessing I run an earth from switch panal to earth busbar!!!. Then from there to house battery earth terminal. But I can’t recal removing such.
Steveeasy
steveeasy
12 Aug 2014
Here is my layout. Quite simple. Just need to know how to earth it.
rogerthebodger
3 Nov 2001
This is that classic misuse of terminology
Low voltage DC systems only have a positive (red) and negative(black)
Mains AC systems in the UK have line (brown) neutral (blue) and earth (yellow/Green)
On my DC system the battery negatives connected to a negative bus in my case via a DC current shunt all instrument negative then connects to the negative bus
The DC positive is connected to the battery positive via a fuse to a positive bus
steveeasy
12 Aug 2014
I’ve run the positive from 1-2 both switch to panel.
I’ve run earth from house battery to earth Bus Bar.
Everything works perfect.
Question.
Why no earth from panel to bud bar? Why does everything work without one?
Steveeasy
steveeasy
12 Aug 2014
2 wires one from 1-2 both switch red to panel.
1 black from house neg to busbar
Boater Sam
14 Mar 2020
Philippines and Thailand
But the panel has no earth. Can’t understand where it is taking it from.
Must be one of my moments I do have a few!!!.
Steveeasy
Stop calling it earth!!!! It is not earth, its battery negative. You will confuse everybody. There is no such thing as an earth on a DC battery system, only positive and negative.
You are making yourself look like a right muppet
The positive goes to the panel and all the switches on it, out to the individual circuits and the negatives for those circuits return to the busbar which is connected to the battery negative so you have a circuit.
The only things likely to have a negative feed on the panel are indicator lamps, some instruments and the warning buzzer all of which are probably on one wire back to the busbar.
steveeasy
12 Aug 2014
Thanks for the complement.!! Anyway all is fine and thanks for everyone’s advice.
Steveeasy
