tomdmx
Hi All, day after the re-launch of our steel yacht I've noticed a slight weeping from the nasa log skin fitting...its an older one and appeared fine (we did not touch it) and now its weeping...
It started with a leak from the blanking cap which we've tightened up but in doing so we also moved the bottom nut..so we have had to tighten that up a bit and used a silicon sealant (not sika) on the outside of the nut (but inside the boat)...now it seems to be very slightly weeping (not sure from where actually ie blanking cap or bottom nut)...and when I mean weeping its moist to touch and a small drip is visible over a period of 24hrs or so on the bottom but that's it (thought I know these things can only get worse)
So am I looking at another lift or is there a way to fix it in the water (ie epoxy or silicon?)..I am a diver so can dive and someone from the yard suggested I go for a dive, use CT1 silicon and run a seal from the outside (apparently it works under water)
