If after soaking it, it still won't budge and you can't get a lever under the outer plate, i would make an extractor. Drill two holes into the outer plate and bolt a bar right across. With a tapped hole on each end of the bar wind in two screws that bear on the flywheel.Hello Everyone,
In need of some advice about removing my damper plate from a 3 cylinder kubota, I have just removed Hurth 100 gearbox for replacement and thought I should replace damper at same time. The sodding thing won't budge though.
Cheers
Give the bolts a good dowsing with Plusgas and wait 24 hours.
Which approach?got it removed guys thanks for your assistance
