wetspot
Active Member
the engine is a Mercruiser 300hp 4.2L VM D-Tronic inline 6 cyl diesel engine
I have had this engine fitted for 2 years and spent a lot of time and money to get it fixed, but it still wont rev past 2500rpm under load, no one seems to know anything about it , since the engine was fitted it has had a brand new loom & harness, new sensors all round, new #1 injector, re-built turbo (as the turbo bearings had failed and veins were scraping the housing). new wastegate valve (as the old one had seized and badly corroded) , new ecm Bosch part number0 281 014 229 (engine was bare engine which had sat at Barrus (uk importer at the time) for a couple of years) , but it still wont go past 2500 rpm, it is fitted in a 1991 Bayliner 2556 command bridge (gross weight with fuel & water 4.2 ton) 9'6" Beam,with a brand new Bravo diesel X 2:1 ratio, origionaly fitted with 22" props, re-fitted with 20"props and no change at all, and has had a new stainless steel fuel tank made (no contamination), I have had the engine read with the diagnostics tool on several occasions and no faults are present (Rinda), and no warning light has come on (brand new dash and gauges), after I reconditioned the turbo, the top speed increased from 7mph to 9.8mph, with the Rinder attached and under load the engine runs fine upto 2500 rpm and throttle position sensor is showing correct position upto that point but as soon as it reaches 2500 rpm the engine wont increase but the throttle position sensor continues upto 100% in line with the throttle position, engine idles at between 600 and 800 rpm, flywheel rpm is same as tacho, no problem there, when I disconected both fuel feed and return (fuel lines are diesel suction fuel lines wo they wont colapse,with internal diameter of about 10mm) from the fuel tank and run the engine from a 5 gallon drum (at same height as the engine and at 1 metre distance from lift pump) at 1000 rpm in neutral fuel return was about 1 litre every 2 mins, when at 2500rpm return was less than this, when in drydock (with water attached) engine will run both in neutral and gear throughout the engine range with no problem, the engine dosn't apear to be strugling at all, but apears to be running in limp mode as far as fuel is concearned, I have just replaced the lift pump, still no change, since the engine was fitted, the battery light has been on (on the dash) but the battery is charging fine and the dash volt meter is also fine, could this be the problem? as the workshop manual states if a reading of bellow 9volts is read by the ecm the injectores dont open fully that is I assume limp mode and the Rinda tool still wont pick up any codes, I have just tested the alternator as per manual tests, it tested ok, as for the battery light, this turned out to be an issue with the split charge relay, now resolved, this is very frustrating as nobody in the UK (Cummins Mercruiser) US EU seems to know anything about these engines, so far I have contacted J Omalley in the United States (mercruiser), Thierry Hardouin (cummins mercruiser) in France,David Jonson (Cummins mercruiser) UK, and several other dealers and technicians worldwide, and still no one seems to know anthing about this engine, please help as Cummins technicians only apear to know about the common rail engines,I have spoke to the nearest dealers to me, most recently Windermere Aquatic, who when questioned wheather they could attend the boat replied 'sorry, no your too far away and were too bussy' when I contacted the other nearest dealers (Conwy and Anglsey) some time ago the stated I was too far away.
The boat is in Fleetwood Marina, Lancashire, but can only be tested (under load) one hour either side of high water, which just makes things even more frustration.
I took the time to take some readings of the Rinda tool today whilst under load at 2500rpm and these are as follows
ECM REF 2.49 VDC
TPS SUPPLY 4.98 VDC
TPS VOLT 3.06
MAP 4.96
MANIFOLD 27 HG
MAX INJECTION QTY 35.5 MG
ACCELERATION INJ QTY 75 MG
Does anyone have any ideas, as I have run out??
I have removed the ECM/ECU which I have sent to a guy up north to test on his 300 D Tronic, and to speed things up, he is sending me a spare 250hp ecu to try, failing that with no Cummins engineers to help, he has also offered to come to the boat to strip the timing cover of and check the timing and get the diesel injector checked as well, has anyone got any idea?
also, has anyone experienced any engine running issues with split charge relays fitted?
ECM REF 2.49 VDC
TPS SUPPLY 4.98 VDC
TPS VOLT 3.06
MAP 4.96
MANIFOLD 27 HG
