jfm
Can someone help me identify/source hydraulic/fuel pipe fittings please? I want to connect the style of hose end fitting in the pictures below to a piece of kit that has a 1/4 NPT female port. The fitting pictured below has a "sharper" cone than the 45 degree cones you see on plenty of hydraulics, and it has an O ring. The lock nut is M18 x 1.5. The bore is around 1/4-3/8 inch. So:
1. Can anyone tell me the name of the fitting below so I can google it?
2. Does it mate with this fitting from Asap? I cannot see whether the Asap fitting has a conical surface on the inside of the fitting - picture isn't clear http://www.asap-supplies.com/marine...r-fittings/racor-union-adaptor-fitting-301982
3. Can anyone post a link to an online supplier of a nipple that has one end with a male M18 x 1.5 thread+a female cone to accept the above style fitting, and the other end with 1/4 NPT male? In stainless steel or brass. And preferably in both a straight version and a 90 degree elbow version. I much prefer an online supplier; I don't want to schlepp to a branch of Pirtek
This is for my generator fuel supply and return. I want to interrupt the pipes and install maretron flow sensors, which have 1/4 NPT female ports. I have some extra OEM fuel hoses as pictured below with these nice end fittings and I want use them, not cut the rubber hoses and use jubilee clip style fittings. Thanks for any pointers
