V1701
Another thread worth a look...
Dylan has a sure-fire way to heat his boat.
Just an obvious, speculative thought which always occurs to me when the dangers of yacht central heating are mentioned...
...isn't it infinitely preferable to have a heating unit which operates remotely from the place where the warmth is delivered?
If the burner could reside in a separate cockpit locker, heating water or air which is then pumped into the cabin, then fumes and moisture caused by combustion wouldn't need any clever removal, and it would alleviate that inevitable grave concern about 'the silent killer'.
I can't think of any yacht I've seen that didn't have capacious cockpit lockers, completely separate from the yacht's interior. So does it make sense to rely on an internal location for a system which, by necessity, pumps out lethal gases, and may even kill through leaks?
Seems like an elementary design decision.![]()
I used to have a charcoal heater which gave out a lot of heat but was messy.
Now I have a very old Taylors paraffin heater which is clean to use, economical and it doesn't require an electrical supply itself. But I plan to install an low wattage 12v computer fan to move the warm air around the saloon.
Seems like a good solution to me.
We use a 'mini' catalytic gas heater, cost around £100 plus around £20 for some piping and a gas tap to connect it to the cooker gas supply (I fitted it myself). Produces around 3/4 of a kilowatt of heat - ample in our 23 footer and we always have to turn it right down after a bit. (There are also larger, more powerful 'midi' heaters (just Google it.)
It's quite small, about 13 inches tall by 9inches wide and 2 1/2 inches deep, IIRC. We intended to mount it on a narrow bulkhead, but found the quoted dimensions don't include the pipe fitting that sticks out of the side, so it wouldn't fit like that. So instead I connected it via a flexible hose and it lives in a small drawer-like locker when not in use, and stands (with a built in fold out frame) on a low step in front of and under the cooker when in use.
It's claimed not to give off carbon monoxide, but will give off moisture. Burns the gas without a flame. We only use it with ventilation and would not (normally) leave it on overnight (though I did once when I fell asleep fully clothed after a long day's hard voyage - no ill effects).
I'd rather have a charcoal or coal stove or other heater with a flue, but space in our current boat precludes it.
We have bought another boat which does have a charcoal heater (Bengco), but the boat's in a bit of a state, and looks like it'll be a long time before that's in the water. Will probably end up using the heater while we're working on the boat ashore.
Would a Samphire Heater suit your Samphire??? I have been using a catalytic heater (portable) but its a bit fumey and dampens up the atmosphere. Am interested in your new boat with the Bengco!
Take a peek on my blog. Alexandria is just 21' and the victory works a treat. Have a CO meter and it never moves from zero. Very warm and cozy. £90 off of FleaBay
Steve
Umm...sorry to be a one-track ignoramus here...not an area I know about...but the deadly emissions theme seems ineradicable...has nobody ever really thought seriously about relocating the heater, whatever it be, to a position where fumes and moisture won't matter?![]()
On a flueless heater most of the available heat is contained in the products of combustion (poc's) so if you put a heater in a safe place then you are not going to get any heat from it.
Some of the mordern heaters need to be in a room no smaller than 80 cubic metres with fixed ventilation of 100cm2 at both high and low level (dont try that on a boat)
What about condensation? Does it create a lot?
lovely dry heat? Well not that much tho: 0.75 Kw according to the Pascal Atkey website. Absolute pig to start (pre-warming flue and having it insulated above deck), very dirty and kept setting off the CO alarm.
