Heater Ducting
AlexL
24 Jan 2003
East Coast
I Have an Ardic Heater on my boat. Some of the ducting is damaged and split and needs replacing, it is 65mm i.d. Any Ideas where I can source this? The current stuff is black on the outside, foil on the inside, with a cardboard tube. I noticed at the boat show that some of the latest heaters had a lot more robust tubing. Is this better stuff available from anywhere?
got some aluminium only ducting which i used for my eberspacher, its 60mm id 2 mtrs long legths, should fit inside of a cut off stub from your old, £12 + p+p
stu
