superheat6k
I would suggest 2 bar or 30 psi but not higher, or you could cause a further problem.The heat exchanger is off! I didn't have the right four sided socket to undo the drain plug, assuming my standard sockets would suffice... no chance... so I whipped the pipe off the bottom of the fresh water pump and that proceeded to dump the coolant into the bilge under the engine perfectly well. I sucked that up with my little 12V electric pump, took off all the hoses, and unbolted the heat exchanger. Very simple indeed.
I next took it to the guys at Welding Services in Kent | Go To Engineering. They were the only solitary lights still on in the trading estate. We were greeted by a very tidy, clean and professional engineering shop. The engineer that (socially distantly) greeted me was very well informed and helpful, and explained everything to my eight year old boy, who had helped with getting the unit off. The engineer cleaned up the corrosion there and then, and to test if it was possible, tried welding a bit to build it up. He confirmed it would be no trouble to weld as they did lots of delicate aluminium stuff (as evidenced by the array of metal work around their shop).
We spoke about pressure testing, and we agreed that it would be fine to just pressure test the raw water cooled side, else we would need to make up lots of plates and gaskets etc. What PSI should he test it at I wonder? That unit above has 30psi written on it? Is there a psi that would damage it I wonder?
