Bobc
Raw water of course, which is why it gets eaten awayAnd what cools the exhaust gasses in the manifold fresh water or raw water
That's about right.Just to flesh this out, so I understand the cooling route - the below shows the 'full' circuit of the fresh water.
Red is fresh water, blue is raw. Clearly I have left the rest of the raw water bit off, and the header tank off. Have I got it right?
If so, it'll be fun pressure testing it
It's not difficult to understand. The coolant system removes the heat from the engine (runs around the engine and header tank in a closed loop, powered by the coolant pump). The raw water removes the heat from the coolant by being pumped through the tube stack (by the impellor) and then the hot raw water is mixed with the exhaust gasses in the exhaust elbow.If you look at MagicalArmchair diagram showing the various flow it looks like the raw water goes through the stack cooling th fresh water which in turn cools the exhaust.
My mobo I have in the UK had a manifold /heat exchanger like that supplied by bowman
Apologies. I now understand where you're coming from. On this engine, the manifold is built into the header tank, so is cooled by the coolant.So are you saying there is no cooling of the manifold itself and the exhaust gasses are only cooled once the raw water goes into the exhaust elbow.
Sorry but the exhaust manifold needs cooling from the first flow of exhaust gasses from the engine exhaust valve/ exhaust port.
My current engine has a fresh water raw water heat exchanger and my exhaust manifold is cooled by the raw water exiting the heat exhanger then entering the exhaust manifold.
Most combined have the fresh water enveloping both the exhaust manifold and the rw water tube stack. so in effect the fresh water cools the exhaust then transfers the heat from both the engine and exhaust manifold to the raw water through the cooling stack the raw water then exits through the injection manifold.
My previous boat with a perkins has a fresh water exhaust manifold and a separate fresh water / raw water heat exchanger.
IMHO, that casting is close to scrap for a repair of any durability, but bearing in mind the ridiculous price of a replacement, I'd try a specialist repairer eg here
Perhaps Google some others as well and Email them a picture to see what they say. It'll have to come off the engine no matter what and it could go in parcel-post if distance is involved. Probably make a hole in your wallet anyways by the time it's filled and machined!
That's about right.
Correct. As you see, this one has been tested.I'm a fan of reusing where I can as well, from a waste perspective. I don't mind paying a professional - and I've had some cracking responses back from some local firms who seem unphased by welding aluminum (as its their bread and butter). They all caveat it with "We need to see it first" of course...
Thanks Bob, I thought so. That means to pressure test it I will need to seal up the port that feeds the fresh water into the block here (as well as the reverse side that the thermostat goes in):
I've found a local company (www.gotoengineering.co.uk) who are open all over Christmas, can pressure test the unit and weld ally - so, fingers crossed. I've booked a half day tomorrow to drain down the system and drop it off, hopefully I'll be able to get it to them before they close tomorrow.
Because 170oC is the maximum working temperature of the paint you cite (which in this instance is a meaningless comparision BTW), does not mean it will break down at 171oC, and with no actual impinging gas flow may well be ok with temperatures way above its rated temperature . And neither is this an exhaust hose, which requires a permanent presence of cooling water. When my engine raw water cooling recently failed and took my engine out , the insurance inspector did not even bother to look at the exhaust. "Oh yes, that will definitely require replacing" was his comment in regard to my inclusion of a new exhaust hose in the new parts list.Yet, the green paint will only withstand 170 deg C. How do you suppose that survives "way, way hotter" than 250 deg C ?
Exhaust hose is typically rated up to 100c, i find it hard to believe that one side of the elbow can only be 100c max, yet the other side is way, way above 250c
I would respectfully suggest that you may be mistaken here.
So I shall disagree with your view I am mistaken, and instead comparing this with paint and rubber hoses is simply irrelevant.
