R.Ems
The valves, whether two way or individual, would always be left open in the seawater position.I would have a valve on the bilge suction line & one on the sea cock. Then whichever you wanted to use is the one you open. However, with those valves are you happy that a visitor would not make a mistake.
Personally I cannot see the point & would just hook a proper pump to the bilge & pump it out, thus bye passing the heads. The benefit of fresh water to the heads can be solved by tipping some in the bowl if it is that important to you.
But i would also take time out to sort the leaks. Just because it is a wooden boat is no excuse for it to leak.
The bilge in question is amidships and I don't want to make a hole in the topsides for occasional bilge pumping.
And I have no excuse for a mast skirt which leaks in persistent rain. None.
