Headlinings again!
nimbusgb
22 Oct 2005
A long way from my boat! :(
www.umfundi.com
Having just spent more than a week stripping out the !"£$%" foul, disgusting, rotted, foam backed traditional headlinings from the storage spaces, lockers and the rest of the boat ( three cabins and saloon ) , I am looking for alternatives to replace the 'traditional' vinyl with. I refuse point blank to have the foam backed stuff on board ever again. It looks ok for a while but as we all know when it starts to go wrong it is a pain to keep in good nick and after 10 seasons or so in the Med it turns into the equivalent of toxic waste as far as I am concerned.
Inside lockers and storage I have stripped back to bare wood or glass, cleaned all the very tenacious contact adhesive of, filled and ground off the big uneven bits and primed and painted satin white. The result is clean storage spaces which are light inside.
In the saloon under the deckhead I have cut 6mm marine ply panels, faced them with white formica and fixed them in place with capped screws. i could have gone for hidden screws but to be honest life is too short! The effect is great. It opens up and lightens the space, it will wipe clean and being screwed in should stay in place permanently.
The small area of unpanelled glass in the forepeak is now lined with a felt type carpet. In the long run I may maye up some ply panels for these two areas.
I am now faced with two large aft cabins, they share the underside of the cockpit, cockpit lockers, seats and coamings as their 'ceilings'. Convoluted, odd shaped and something of a pig to clad.
Currently I have painted them white and to be honest the past month in on the boat in the Greek sun has been a pleasure with the temperatures in the cabins remaining very acceptable.
I'm looking for alternatives to fitting these two cabins with replacement foam backed liners and wonder if there is an alternative to ply panelling. I am aware of the newer, all vinyl, padded liners, but I'm also loathe to go and plaster contact adhesive over everything again!
I have taken the following approach:
Remove foam backed vinyl and glue residue from ceiling (what a joy that was).
Glue little wooden blocks 1,5 cm thick at regular intervals with epoxy against the ceiling. These will be used as anchors to screw into.
Put white simili leather on bathroom plywood panels, after the panels were fitted (I made cardboard templates first)
The panels are held to the ceiling by wooden lats, these are screwed into the blocks that were epoxied against the ceiling.
PRO
The lats are placed in fore-aft plane, so give the impression that the boat is longer
The spacing between the ceiling and panels stops condensation (never expected this. What a difference)
The spacing is used for recessed LED lights. Spacing is also used to hide cables.
Panels can easily be removed for inspection of cabels
CON
Lots of fitting
You lose 3 cm headroom.
Does anyone have any thoughts on using carpet for headlinings?. A boat I'm interested in buying has carpet everywhere. My guess is that it will be really hard to clean, and thus grow moldy and smelly.
You can get this vey thin lining material about 3mm thick like very thin woven carpet with a corduroy effect.
I have used it on my shelves in the lockers.
I bought a boat a few years ago whose previous owner had used upvc cladding. It looked very good and allowed cables etc to run behind.
I have recently refitted a small 19ft yacht using the same materials and although quite fiddly the results look pretty professional (provided you use lots of bits of quadrants, cloaking trims etc to cover the ends, corners etc.
Quite reasonable too as long as you don't go to one of the diy warehouses. (I used Eurocell)
btw the cladding I refer to is hollow soffit board, 100mm wide
I'm going to use the same method as Kingfisher as it makes it simple to replace damaged headlining and get to all the deck fittings easily. On bits where I can't fit boards like the curved sides of the saloon for example I will use the normal headling but use battons to keep it there.
I am also planning on using some of that insulating bubble wrap in the gap between the boards and deck.
