Having decided on a colour for the awning
Wansworth
8 May 2003
SPAIN,Galicia
What shape and means of fixing .Potential boat has lazy jacks and a main sheet in front of the companion way.Best suspended under the boom with a cut out for the main sheet.
Lazy jacks are only needed when you lower the sail and if left up while sailing will chafe the sail
so keep then pulled forward at the goose neck until you need to lower the sail and that's the only you need then aft
But what do you do with the lazy jacks?
In my photo in your previous thread you can just about make out the lazy jacks alongside the mast, as said, pulled along to the gooseneck. The lines you can see hold up the ends of the grp poles, Vango 3 metre tent poles. These are tied down to the guard wires. This is a far better arrangement than the widely seen tent style draped over the boom but there was quite a lot of construction sewing to get them right.
Ok,thanks……with all this heat I was keen to sort out the idea of a canopy asp…I have a sewing machine that does sails so might cut up an old gaff mainsail……not much call hereabouts 😂
Get rid of the mainsheet by disconnecting it from the boom and tying the boom to the backstay (maybe not in that order, especially if it's breezy) and run a line under the boom from the kicking strap fitting to the mainsheet fitting. Tension it with a trucker's hitch. Much tidier than over the sail, and you don't have to disturb the lazyjacks
To keep rain off, a tarp from the Spanish equivalent of Toolstation, if you're only bothered about sun, we use a king-sized bedsheet with loops sewn to the corners.
