Plum
Has your NASA SX35 DSC VHF lost it\'s MMSI memory?
My NASA SX35 DSC VHF, which I purchased last summer, has just lost my MMSI number from it's memory. This is a nonvolatile memory so does not rely on power.
NASA has offered to correct the fault without quibble, but the issue I wanted to alert others to is that you get no warning about this memory loss until you try using the DSC function.
If I had been in distress and pressed the red button under the cover the signal would not have been sent as my MMSI number would not have been in the memory.
Other MMSI numbers that I had entered into the directory had also been lost.
I recommend you check that your MMSI memory has not been wiped clear BEFORE you need to send a distress message.
Please let me know if you also have the problem.
