Has the Shipping Forecast improved recently?
capnsensible
15 Mar 2007
Atlantic
Shipping forecast nostalgia.
A million years ago I was taught how to write the forecast in shorthand and then draw a synoptic chart based on that with isobars, fronts, etc. Used to get pads of a pre printed format to draw on.
Was never a great success!
lustyd
27 Jul 2010
Why pay when it is all free, paid for by taxpayers?
Because it's not all free, and because GRIBs aren't a good way to show weather. The free ones are not great resolution so you'd end up paying anyway if you wanted to get good information. A grid is a terrible way to show a weather system and how it's going to move, the forecast tells you where the system is, what direction it's going and how fast. Using a GRIB you'd need to reverse engineer that information from your gridded info otherwise you're just looking at grid points and assuming what it says will happen is going to happen, and that's not usually the case.
franksingleton
27 Oct 2002
UK when not sailing
weather.mailasail.com
Mostly the commercial GRIB products are derived from the GFS. They are just re-hashing the data. You get no more information. There is little difference between models for the first 4 or 5 days. Watch Windy.com to see a comparison between GFS, ECMWF and the German ICON-EU, their 6 km Europe model. Differences are usually within model uncertainty. If one is significantly different from the others then the situation is more unpredictable than usual. Claims of high precision and high accuracy are nonsense. Weather is never precise. Remember that the effective resolution of ANY NWP model is about 5 grid lengths.
Also, remember that small weather details have short lifetimes. A large thunderstorm has total life of around 6 hours max. By the time data are collected, analysed, a forecast run and distributed it is about 7 hours for ECMWF, 5 hours for the GFS and 3 hours for ICON-EU. Private sector modelling companies cannot analyse detailed data. They simply interpolate from global models. National weather centre detailed models do use detailed data but still come up against the lifetime problem. Models are useful to them but by the time we see the output, they are of little value for the vast majority of sailing applications..
Sandy
31 Aug 2011
On the Celtic Fringe
duckduckgo.com
Pads are still available I understand. Otherwise download them off the internet. ?
franksingleton
27 Oct 2002
UK when not sailing
I wrote the RYA training manual on this some 50 years ago. It was a hairy exercise but life has moved on. Short term, small detail is still a problem. Outlooks for several days ahead we’re a pipe dream in those days. When cruising nowadays we can often be fairly sure about plans 5 or y days ahead.
lustyd
27 Jul 2010
I think you’re confusing some things there. The higher resolution reflects the additional processing it doesn’t offer higher precision. The output is better because more data is used and processed. The model is the same but the output can and often is different. Lower resolution is cheaper to process and often good enough. In both cases gribs need to be interpreted back to weather though.
franksingleton
27 Oct 2002
UK when not sailing
It all depends on what you mean by accuracy and precision. In the 1970s the Met Office large scale model used a 300 km grid. Its fine scale model used 100km. Their global model is now 10 km and the detailed model about 1.5 km. in the late 70s, we were just starting to see skill at 5 days ahead in model output. Now TV forecasters, sometimes, have confidence up to 10 days. Obviously, more data at higher resolution and models able to calculate the physical processes meaningfully at high resolution produce better, more accurate forecasts.
However, when Predivtwind, as the best known example, quote accuracy and precision, they are referring to verifications at a point. That is what you and I will experience on our boats. The point that I am making is that Weather is not precise. Nor are models. The highest resolution global model grid is around 10 km. effective resolution is about 50 km. Models have to have a built in smoothing. Grid lengths of high resolution models such as the Spanish use of HARMONIE use a 2.5 km grid. Effective resolution 12 or 13 km. the French AROME grid is similar to the U.K. Try using the Meteociel site Ensemble link to see the spread of values of wind speed.
PS. I do not know if this will work. Look at Meteociel.fr - Tableaux PE-AROME. That is the AROME ensemble, winds are in km/hr. Look at the spread of wind speed. What do you mean by accuracy?
lustyd
27 Jul 2010
That was sort of my point in the first place. Knowing where a weather system is and its direction is more useful than a bunch of points which you have to manually build back into knowing where the "weather" is likely to be and where it's going. It's of no use to me knowing that at a given grid position the model thinks the wind will be 13kt westerly at 4pm unless I place complete trust in the accuracy of the model, which I don't. If I know that something is blowing through just north of me then I can at least make an informed choice about risks over time.
franksingleton
27 Oct 2002
UK when not sailing
Surely, that is what GRIB viewers do for you. A good viewer, XyGrib is one, will give you isobars, rain areas, wind speed and direction etc
capnsensible
15 Mar 2007
Atlantic
Thanks, Frank, for your clear explanations on these weather threads. It's great having someone on the forum who has not only been a career weather forecaster, but is a sailor too.
My bit of seaweed has become redundant now I live in a place where it hardly ever rains!
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
I depend on a rock on a string. See Weather rock - Wikipedia
Black Sheep
13 Nov 2005
East coast, UK
I think you'll find that it's the rock that depends on the string...
(Edit: now that I've taken the trouble to check, I see that in this meaning of the verb, the preposition should be "from". But saying "it's the rock that depends from the string" doesn't quite work. Ah well, it was funnier in my mind)
AntarcticPilot
4 May 2007
Cambridge, UK
GROAN!
In full, I depend on a rock that depends on a string. The string depends from a fixed point of attachment whose choice depends on availability and personal preference. I can depend on a rock depending from a string because even Martian Rovers depend on a high-tech rock on a string to provide wind and weather data.
I think that breaks every rule of good style that I ever learnt, depending, of course, on which manual of style you depend on ?
