Jobs a good un
Hi All
Looking to get a new dinghy around the 2.6 m length , can anyone advise on good models ?
Regards
Mark
Regards
Mark
Hi All
Regards
Mark
Have a look at sunsport 27
I fully agree. We had a Quicksilver 2.7 Airdeck, same boat now re-named. We owned it for 12 years, almost always in the sun throughout the Mediterranean. It rows very well and is altogether a delight. No deterioration of the material in all that time except for the Airdeck, which was replaced with a far superior design. It was a little too big for our foredeck so we sold it to a friend two years ago, who is delighted with it. We replaced it with a Sunsport ARIB 2.3, which is nowhere near as good.
Vic,
Would you mind expanding on why you think the ARIB isn't as good?
John
The hull compartments refuse to hold air. The valves have all been replaced but made little difference. The inflated hull makes the boat float higher, which gives it initial tippiness that can be disconcerting. This feature also renders it far less pleasant or easy to row. If we always used an outboard the latter would not be a problem but in fact we only use ours a couple of times per season. The inflatable hull is very bulky, so the boat does not roll up and stow well.
Pioner Mini 8.
A bit heavy,
http://pionerboat.com/pioner-8-mini/#1488276002453-f2e40ffd-1d926eb2-c92531e5-c61f
We've had an AB rib for 10 years and it's fantastic, planes with 4 people with a 9.8hp Tohatsu and all hypalon so tough as old boots. Ours has a fibreglass bottom so a bit heavy, dealt with using davits on the boat and dinghy wheels on the stern for pulling ashore. What I particularly like about the AB design is their high bow so they are much dryer in any kind of sea or chop. Current models are in aluminium hence lighter but not tried one. Ours is 3.2m but they do 2.8 and 2.6m version IIRC.
Having said that If I was changing I'd seriously consider a Ribeye - attractive and very well thought out boats. Saw some when we were on the Dart over winter and thought they looked great.
Never seen any rib plane with four adults and a 10hp engine. Are two of the people kids? Normal rule of thumb with ribs is 5hp per person. Having said that we have had four slim adults in a 9ft rib, large planing plate and 15hp two stroke plane quite well but with lots of throttle.
Apart from a standard rib the only other tender I've ever considered is a Walker Bay simply because of thebchance to lark about sailing in it. Somewhat more expensive though so I never took the plunge.
Mmmm The Pioner boats look like fun, they appeal to me. However, how buoyant are they when pierced/punctured I wonder, I prefer the three compartment air-tube arrangement, which in the event of one puncture, or capsizing, you should be able to overturn and get back to boat/base. Mind you, its been over 5 years since I did my Sea Survival and overturned a liferaft....!
