GEM43
The innards of those Hozelock hoses are excellent for fitting to the dehumidifier as a drain hose. So when it fails cut a few metres of the inner pipe and put it in the “that’ll come in handy one day” bag.
Mine sprung a leak at one end whilst using it at Universal Marina where the pressure is high.Which is what happens when you turn off the supplied spray nozzle.
One hose split the inner and was leaking inside the outer skin, the other split at the tap connector end.
I did repair them but soon leaked again.
I used to use it to top up water tanks but I use inline 10u and 1u filters before the tank and a tap filter at the galley for drinking water.
I used both expanding and normal garden hose to fill up my water tanks.Are they OK for potable water?
It would be hard for water to pick much up when flowing quickly through a hose. It matters for pipes on board where water may sit for a while but not at all for hoses to fill tanks if you flush them through before starting.Are they OK for potable water?
I thought this was about garden hose,what’s all this boat stuffI have found that 'standard' hose is just not thick and strong enough to avoid kinks. I once splashed out and bought some relatively expensive (twice the price?) higher quality 'heavy duty' hose as a present for my ex, an avid gardener, and was impressed by its durability, resistance to kinking and to pinhole leaks from being dragged over stones etc. It is also strong enough that it isn't damaged by being driven over on e.g. a road or drive. I later bought another reel's worth of the good stuff for boat use when my boat was parked ashore a huge distance from the nearest tap, needing a series of hoses to reach.
The good stuff I have is yellow (black inside IIRC), and rubbery in texture, as opposed to the plastic feel of standard hose. A good length reel of this is very heavy, but it has lasted years, and certainly much better than the standard hose I also have which is still in occasional use (often needed in series to achieve length) but so annoying to use because of numerous kinks that have developed and the need to cut out ends or sections that have developed leaks.
This good quality hose is far too heavy and bulky to keep on my smallish boat, and for cruising the boat has a couple of 'cassette' type reels of 'fold flat' hose - not very durable at all, but more practical afloat.
