Harken 44.2 electric winch repair
dgadee
13 Oct 2010
My Harken 44.2 electric winch went at the end of this past season and just reporting the repair here in case anyone searches the forum for information. When I took it apart it was in pretty bad state with the two top bearings rusted away causing the gears to be damaged:
This required a new gearbox. I got this from Rundles of Bolingbrooke (£190 + vat) and they also took the shaft off the old gearbox and tapped the new gearbox for 8mm bolts. Quite expensive old business (£75 + vat), given that the cause of it was a simple seal which should have been replaced - item 3 in the diagram:
However, it's awkward to get at so I'm not surprised it wasn't replaced.
This is a 50mm Vee ring A type seal. The gearbox is a Bonfiglioli MVF49 / P 24:1 P71 B14. APT Powerdrive also do this - same price as Rundles. In fact they supplied the gearbox to Rundles.
There are two winch systems - blue and white. This is blue and white may differ.
Harken appear not to support this winch anymore.
I also got an electric motor shop to look at the 12v motor brushes. They said they looked like new, so I presume that the motor usage is not heavy.
Good thing you found a way to get the beast repaired. :encouragement:
I am SO glad I have only manual winches on board (All Harken) . Mind you there are 6 to deal with over the winter.:rolleyes:
Dear forumites,
Just wasted an hour of my life itemising all the part no's, dimensions & sources for all the bearings & parts for Harken 44.2 Electric winches & a couple of tips for stopping the damage happening.
I must have pressed a wrongtit, so it's all disappeared. signed R. Feckett
If anyone needs help PM me.
I would like to PM you, but as a new member I can’t! I have a 44.2 electric Harken, and the motor is without power. Could you sent me the partslist?
