shortjohnsilver
Had an issue when unfurling the Genoa yesterday (in relatively benign conditions fortunately ) where I had a bit of halyard wrap, preventing the Genoa unfurling.
I was able to back the sail and the wrap unwrapped itself, but when recommencing the unfurl, again the haliyard wrapp and jammed at the very top. I and had to utilise the same method of backing the sail against the wind to free it.
Furled it back in and as I did so I could see the Haliyard flicking back catching, wrapping maybe a half turn, then flicking back again.
This morning had the Genoa down and examined the top furler, which is fine and rotating well. Nonetheless I washed it out let it dry and lubricated it with dry silicon lubricant spray. It was spinning completely free. Back up with the Genoa and really the same situation persists. It seems that the haliyard exits the mast and drops to the top of the upper furler. As it does does so it sort of passes around bends around a deflector, that is supposed to ensure haliyard wrap wrap doesn’t happen.
The facnor booklet refers to this deflector as a deflector ‘wheel’ ?
Wheel to me intimates that it rotates. But should this deflector rotate or is it static?
I understand that there needs to be a reasonable amount of tension to retain the haliyard lead correctly. So I tensioned the haliyard and this seemed to make things worse. I relaxed the tension and there was an improvement. The Genoa furls and unfurl easily now without any use of a winch - as it has always been the case - but I can still see and feel to a degree, the haliyard flicking back and forth around this deflector wheel and not sure that it should.
If this deflector wheel should rotate then I’ll need to get up there and free it off. If it doesn’t and that would be my thinking, then is there an issue with the forestay ?
Bloomin’ hope not!
Sorry for the length of this post, but I was hoping that there are some forum members who have or have had experience with the Facnor furling gear and might be able to give some advice or even put my mind to rest. The boat is Beneteau 36 double spreader rig with a massive Genoa and to have this problem when at sea in difficult decisions will not sit well with my Mrs.
Bloomin’ hope not!
