mocruising
I have a reasonably well know GRP cruising boat build in Sweden with a big blue stripe round the topsides. Two years ago we sprung a leak in the water tank. (Tank capacity 1000 L) Actually its two tanks adjacent in the floor with a common pipe and only one filler. The tanks are installed under the floor prior to putting the deck on the boat so each individual tank could not be removed by conventional means. Both tanks sit above the bilge and do not come in to contact with accumulated bilge water. To cut a very long and expensive story short we had to remove the tanks from the floor, build a habitat down below, cut the tanks in half with an angle grinder and remove them. We built new tanks out of food grade SS in three sections so they could be installed down the hatch and joined them all together. For the past ten years we have never chlorinated the water.
The two leaks were from the inside out and were at the weld points. (Perforations) We could have patched them but considering all the work and thoughts of more perforations we replaced them. The boat has spent about two thirds of her life in the Med and completed one trip to the Caribbean and was shipped back. We were in Greece the three years before the tanks started leaking. I always load water through a 10 micron filter. The water in parts of Greece can be very hard. Although we always top up our fuel tanks for winter lay up in the past we never bothered to either top up or drain our water tanks. We have a water maker but its the one bit of equipment that we have never used. It was used by the previous owner. For the past ten years the boat is parked on the hard from Oct-Nov. through to April- May.
We now load all our water through a water softener plus ten micron filter and when ever we leave the boat for any length of time fill the water tanks to the top. The theory here is to exclude as much oxygen as possible, I do realise water contains dissolved oxygen.
Five years ago we had to replace both the SS holding tanks due to perforations but we replaced them with plastic which was the recommendation from this forum.
I can understand the holding tank issue but have we just been un-lucky or have others had similar experiences.
