Bouba
The thread started with the ridiculously high cost of repairs to the Seakeeper and the theory that the simpler MC2 might be cheaper to repair. This should be a consideration I think, also the website for MC2 suggests that it can be put on smaller boats, a consideration for many here. Also by fitting several smaller units the Italian may fit where the SK can't. And my theory that you could add units until you get the desired effect. But I agree the MC2 do themselves no favours with their pricing..When I spoke to the MC2 guy I asked him how many units had been supplied and like Jimmy he said 80 units last year but then when I asked him to name some boat models they had been fitted to, he wasn't able to quote one. Quick is a well known Italian manufacturer/supplier of marine equipment like anchor winches, thrusters etc and their stuff is found on many Italian production boats as OEM equipment so I have little doubt that Quick can support the MC2 product. The question is how much of a guinea pig do you want to be to save a few bob over the proven Seakeeper unit
One point to note is that on a like for like basis, the MC2 is significantly heavier than the equivalent Seakeeper which might have an effect on fitting costs. It seems that MC2 use a heavier flywheel running at much slower speeds in fresh air to achieve the required angular momentum whereas Seakeeper use a lighter flywheel running at much higher speeds in a vacuum. The latter might account for the fact that the Seakeeper appears to have a longer spool up time.
I can see advantages/disadvantages to both types but I still can't get my head around the fact that the MC2 is nearly as expensive as the equivalent Seakeeper despite being a much simpler less sophisticated unit and having zero presence in the leisure boat market. Maybe they would give a substantial discount to an early adopter?
