How about doing a course? It would steepen your learning curve considerably and instill a lot of confidence. You would also learn about navigation, weather and collision regulations etc.
I find it a bit of a pain. In the video the rudder is on the point of stalling in gusts when heeled and needs attention all the time. I changed the blade from the original design to a deeper straighter one (from a pattern of a Prelude rudder) and it transformed the boat. I could sail it hands-off just using the mainsheet to steer. In gusts it stopped whinnying about, but you did need to be aware it may be more likely to knock-down in a really big gust.Gently rounding up when very overpowered in gusts is a good feature IMO and not something you should be worried about. Better that than the boat going on it's side. A steady hand on the mainsheet will sort the boat out for most minor gusts. If you think the wind is going to stay like that then pop in a reef.
I love this site and I hope the OP doesn't begrudge my jumping in here and thanking everyone for the invaluable advice. I'm guessing I'm about where the OP is in terms of experience and what feels comfortable (I didn't have the dinghy grounding though) and we have similar boats. The knowledge and confidence that a thread like this builds is fantastic.
Interesting. We do that 24 times a day when trialling. It makes it a steep learning curveIt's known as the "Kolb Learning Cycle"; Plan; Do; Review and is how we learn to deal with stuff.
In a boat that small I might be inclined to play the main sheet rather like on a large dinghy in effect, rather than cleating it off & then releasing it completely, I would hold it in my hand (possibly use a ratchet block to ease the load) & just let a little slip out to spill the load.
You're meaning like 3minutes/10seconds and 5minute/40seconds in this video. This is a 17ft dinghy-like boat. Probably not as tender as a micro cup boat. Having said that a micro cup boat will have more ballast lower down. I tended to sail with the mainsheet in my hand so I could dump it if needed, but to try and hold my course as the gusts on the lake are only short.
Once you have the confidence in the boat you will feel much happier. Personally I don't like a boat which rounds up into the wind on it's own. It means you are no longer in control.
If you are sailing single-handed it may be an idea to re-run your headsail sheets if they are tricky to reach at the moment.
On Feckless the sheets were cleated on the coachroof which was hopeless. I led them down the coaming using bullseye fairleads and turned them using cheekblocks. On my boat there was a drain channel in the seat which allowed me to lead the sheets down to some cam cleats.
You can see how this makes it easy to handle on this vid at 45 seconds and at 1 minute/40 seconds you can see my foot-cleating technique.
Nobody saying they've been heeling over 10 times more than that for 30 years
It also leaves the forward part of the cockpit clear for non-participating passengers.I like that, I like that a lot.![]()
........If you are not very experienced you should learn that failing to ease the main during a gust can cause some boats to round up, and sometimes it is impossible to bear away without easing the main. It is an auxiliary rudder.
