BabaYaga
In this thread from the other day
http://www.ybw.com/forums/showthread.php?482576-Holding-tank-sea-cock-failure&p=6128396#post6128396
and in many others the problem of holding tank blockages are discussed. It appears to be a fairly common thing. Many forumites witness of having to "rod out" from below or from above, through a suitably positioned deck fitting..
I get the impression, but could be wrong, that this problem is associated only or mostly with gravity drained tanks.
On my boat the holding tank is under the fore peak bunks, with the tank outlet well below the water line. For discharge to the sea, a diaphragm pump is used (another option is emptying at a pump out station, through a deck fitting). In 35 years of use I have never had a holding tank blockage.
Could it be that gravity drained tanks are more prone to block? If so, what could the mechanism be? My own thinking is that a length of vertical exit pipe would more easily get clogged by dense matter compared to a length of more or less horizontal exit pipe typical of a tank at or below water level.
