Bilge Rat
Wife of Bilge Rat here....
We have a GRP water tank moulded into the floor of the saloon, having noted some distinctly "eggy" smells coming from the taps we investigated and what we found when we took of the inspection hatch has driven us onto bottled water for drinking. We have to sort it out but would appreciate some good advice on the best way forward.
The tank is gelcoated and a baffle situated near the top of the tank has clearly been damaged and lost some of the protective gelcoat. There is an area of fibreglass exposed (I seem to think that this may give off some noxious substance) so now I have worried myself.
The smells may have been more down to water stood in the pipes for 2 weeks but we also found a large qty of "crud" at the bottom of the tank together with some slime on the top of the tank so everything needs a thorough cleaning this winter and of course the repair to the gelcoat.
Initial thoughts are to dry the tank thoroughly in October and repair the gelcoat prior to relaunch next spring but there are so many questions in my head.
1. Will saturated glass fibre really dry out without heating in a few month?
2. Will I make the situation worse if I repair before dry and trap in water?
3. Do I need to consider a liner?
We need to get this right as we will be cruising for a few months next year and I want to be able to confidently drink the tank water without fear of disease or poisoning.
Thanks Jackie
Thanks Jackie
