CAPTAIN FANTASTIC
I would like to buy a thick 10mm to 25mm (1/4in to 1in ) by 300 by 700mm (or similar dimensions) board/panel made of GRP. Where do I get a GRP panel from?
What you describe is not available off the shelf; you can buy foam or plywood sandwiched with GRP on the outside. What's it for?
Why not use a strip of hardwood, that's what mine has.
I think you need an expert to tell you what you need cos' your ideas are daft! Sorry to be blunt!
How were you going to stick Stainless Steel shoes on?Yes, but the trouble with wood it is difficult to "stick" on and make a good bond on the existing grp bottom of the keel.
What you describe is pultruded GRP plate, I can possibly get you some 12.7 mm plate off cuts from my company workshops. You mentioned a size of 300 x 700, but what sizes had you planned to cut these to? However, by definition, it is flat and straight, really not easy to cut and shape to suit a shaped keel. Suggest better to mould something.
Make a mould and then construct a GRP shoe which you can stick on with Sikaflex. You only need one male mould which replicates the bottom of the keel going about 75mm up the side, and then laminate GRP over it. The mould can be made of softwood, painted and coated with release agent. Finish the outside with epoxy and antifoul.The bottom sacrificial grp skin of my twin encapsulated keels is wearing off; It is common to Macwesters. I have a few options; I can make stainless steel "shoes" and dress the bottom 3 inches of the keels; build up the thickness with glass cloth and grp in situ; or get a thick grp sheet and cut it out to shape and stick in place with grp and cloth.
Doing it in situ, layer by layer, it will be difficult because I will be working up side down and there will be very little working space between keel and ground. Fabricating stainless steel shoes requires much more specialism. So, if I could get a thick grp sheet it will be much easier to do the job. If I can not get it ready made, I would have to make up the right size and thickness at home and then stick it well with epoxy on each keel.
where from?What you describe is not available off the shelf; you can buy foam or plywood sandwiched with GRP on the outside. What's it for?
