ripvan1
Whilst googling I came across a suggestion to use a baking soda paste, anyone ever tried this or got any other ideas that do not entail chandlers' products.
any acid will pull out the brown staining from GRP - commercial hull cleaner (Starbrite for example) is Hydrochloric I believe.
Starbrite Hull Cleaner is oxalic acid - less than 10% acid, incidentally.
I think it's very irresponsible to suggest using "any acid".
The Starbrite barnacle version is Hydrochloric Acid.
If you are talking about brown rust stains, you need Oxalic Acid. Just buy the crystals and make your own, 100g per litre.
Wear gloves and eye protection, and don't get it mixed up with the sugar!![]()
thanks all, think i will try baking soda paste and then sillet bang out of curiosity then oxalic acid. i'm prone to panic attacks when entering chandleries
Don't get it in your eyes, eh ?...what can possibly go wrong?
thanks all, think i will try baking soda paste and then sillet bang out of curiosity then oxalic acid. i'm prone to panic attacks when entering chandlers
I wonder if it's the same 'oxy' that gets put into the washing machine and costs a hell of a lot less...any one know?
No not if you mean the "oxy action" bleach like Vanish. That contains a peroxide that releases oxygen.
This is oxalic acid, one of the stronger of the weak organic acids.
It is:
harmful if swallowed, inhaled or absorbed through skin;
corrosive - causes burns,
very destructive of mucous membranes
and may cause congenital malformation in the foetus.
It is the substance which makes rhubarb leaves poisonous.
