Grease for Stern Tubes
philmarks
New Zealand
www.blue-hound.com
Vessel's steel, stern tube is steel. I'm currently using Duckham's Keenol grease, which I believe is lithium based. I read somewhere recently that lithium is a bad combination with steel and salt water. Is that correct and if so can anyone recommend a suitable grease? I bought a large pot of stern tube grease from ASAP and that's also lithium based. All the greases I've seen are lithium based.
Phil
Avocet
3 Jun 2001
Cumbria
Has never given me a problem!
I doubt Duckhams would have developed a waterproof grease that's no good for steel in salt water - -there wouldn't be much application for it!
neilsan
15 Oct 2002
Hi,I had a steel ketch with steel stern tube and for 17 years used waterproof axle grease as used on boat trailers it did the job and was a lot cheaper.
Mirelle
N/A
30 Nov 2002
Well, I have a bronze shaft in a bronze stern tube, so iy might be different, but I have always used Duckhams Keenol. It says on the pot "particularly suitable for marine applications including stern tubes", so I believe it! I also use it on galvanised shackles and the large ancient galvanised windlass and it seems pretty OK there too!
ccscott49
7 Sep 2001
Same here, but I use whatever I can get my hands on, as long as it says for marine use in sterntubes etc.
iacle
22 Jan 2003
Isle of Man
Alternative to keenol
It seems Keenol is hard to get hold of since Castrol took over Duckams. None of the stockists on the Isle of Man have any! Does anyone know an alternative brand name suitable for stuffing glands? A local agricultural dealer has JCB lubricants which include a lithium based corrosion resistant greases and a water resistant aluminium complex based grease. These are both NGLI 2 spec, as is Keenol, whatever that means. Would these be ok? Would I be better with the lithium based one, as it will be mixing with Keenol already in the stuffing gland?
<hr width=100% size=1>Ian
maris
17 Jun 2002
Scotland
Re: Alternative to keenol
A lithium-calcium greese worked ok for me last year. When in the outer isles this spring I bought a tin of sterntube greese. No company name, just stern tube greese writen on the tin. I think the point Im trying to make is try comercial chandlers.
DMGibson
4 Oct 2002
There's a company called Vickers in Leeds which makes a grease specifically for sterntubes - it's call "NEOX" and the usual grade is DT. I believe it is made for commercial vessels, but that doesn't stop us using it as well.
It is excellent stuff, and I also use it as a general grease wherever it is likely to get wet - shackles, rigging screws, anchor windlass etc.
The only problem is where to get it - I have found it in commercial chandlers (Cosalt in Lowestoft), but only in big tins - about a gallon! Still, I can keep re-filling the small tin I keep on the boat from the big tin.
tr7v8
30 Nov 2001
Kent
My local chandlers told me that they've stopped making Keenol and I ended up buying another waterproof grease which is evil and brown. Does anyone know if this is true?
<hr width=100% size=1>Jim
Draco 2500
Forbsie
9 Mar 2002
Untrue. I use Keenol and have seen it in chandlers around here. If you still have trouble getting some, get <A target="_blank" HREF=http://sillette.co.uk>Sillette Sonic</A> to send you a tub.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/forbsie?&page=1>My Project</A>
