stuartwineberg
Port engine on my Hardy 36 (semidisplacement) is overheating. Sabre Perkins 265. When I tootle along at 7 knots runs all day at around 82 degrees same as Starboard. When I wind her up a bit to around 10knots at 2100 revs the temperature creeps up over about 5 minutes to around 95 before I lose my nerve and slow down. Strainers clear, inlet not easy to ream out but a quick "flood test" with the top off the chests shows water coming into the strainer on both port and starboard sides at about the same rate. Ditto coming out of the exhausts on tick over. Water flow appears to increase signicantly out of the exhaust when I rev up in neutral. Impeller cover quite cold.
My thoughts - vane gone on impeller. Thermostat jamming. However a fairly well informed contact tells me that modern thermostats tends to fail open not shut and so wouldn't cause this problem.
Over to the wisdom of the forum. (BTW it is a pig of a job to get at the port impeller!)
