Plevier
Thanks for the reminder, I should take that down ...
You can feed the balanced output via a 1k resistor to an optocoupler, feed the output to the device via another 1k. It might work ...
Ignore the pin numbers!
Optocoupler example: http://uk.farnell.com/vishay-semiconductor/cny65/optocoupler-transistor-o-p/dp/1469507
Thanks will investigate that but will take a bit of time. I can't buy one off from Farnell can I, would Maplin do anything suitable? They have these http://www.maplin.co.uk/productsearch?criteria=optoisolator and this http://www.maplin.co.uk/productsearch?criteria=optocoupler
Question - I thought the standard was space high, mark low but this appears to be mark high doesn't it?
