James Marinero
New Scientist is reporting an apparent GPS spoofing 'experiment' in the Black Sea., quote:
'Reports of satellite navigation problems in the Black Sea suggest that Russia may be testing a new system for spoofing GPS, New Scientist has learned. This could be the first hint of a new form of electronic warfare available to everyone from rogue nation states to petty criminals.
On 22 June, the US Maritime Administration filed a seemingly bland incident report. The master of a ship off the Russian port of Novorossiysk had discovered his GPS put him in the wrong spot – more than 32 kilometres inland, at Gelendzhik Airport.'
Do you monitor your track and/or keep paper plots going? For me, a 32 km diversion would be obvious. However, if the 'errors' were smaller then it might not be so obvious - but still be accumulate enough to cause a problem. Checking compass bearings, depths and using all the inputs you have access to - and applying common sense is always good practice.
Full story at
https://www.newscientist.com/article/2143499-ships-fooled-in-gps-spoofing-attack-suggest-russian-cyberweapon/
Full story at
