webcraft
Re: Compass display vs highway
Using XTE and continually correcting your heading to stay on track keeps distance travelled over the ground to a minimum.
Most navigators believe, like yourself, that drawing a traditional triangle taking tide and leeway into account for every hour on passage and adjusting your course accordingly will minimise time on passage, but that on some passages (eg cross-channel) it is possible to work out and allow opposite tidal effects on passage to cancel each other out. Either of these traditional approaches can be rendered very much less efective by inaccurate tidal information, inaccurate estimates of leeway or inaccurate predictions of boat speed based on inaccurate forecasting of sea or wind conditions.
I have seen it argued that using XTE to minimise distance travelled will have exactly the same effect as doing the full calculations even when everything goes according to plan. I am not enough of a mathematician / geometrician to work this one out - perhaps others would like to take this up. I certainly do not believe that you would beat me every time across the channel if I followed a direct track and you used all your navigational wiles - although you might a majority of the time.
However, I think you missed the essence of my post. The person who started this thread sounded as though they wanted to make the GPS their prime method of navigation. Bearing this in mind, what I said was that XTE was more important than heading to waypoint. By following your track you are certain of getting to your destination safely - the primary objective, surely. Blindly adjusting course to follow a moving bearing to a waypoint, however, may well end in disaster.
Of course anyone who is comfortable with GPS and trad nav can mix and match the information in a myriad of ways - using the drift off track or heading change to waypoint over time to calculate leeway, working out clearing lines of lat and long on the GPS etc - but if unsure, plot a safe track and stay on it - works every time. It's also an accurate way of crossing shipping lanes at the prescribed right angle.
- Nick
<hr width=100% size=1><font size=1><A target="_blank" HREF=http://www.bluemoment.com>http://www.bluemoment.com</A></font size=1>
- Nick
