Allan
I'm having trouble connecting my new Bluenext GPS dongle to OpenCPN 3.0 does anyone know how to do it? I'm sure I am missing something simple.
Allan
Allan
Allan
if you type "device manager" in the start menu, the device manager should appear, click on that the there should be a "ports" entry. In there you should be able to see which port the dongle is in. Then put the same port number into the "nmea data source" box in the gps tab of the toolbox.
Hope that works.
This works if the OP is using Windows. Linux is different, and OpenCPN works on Linux.
Hope that works.
...make sure you set the right baud rate as well...
...if your a Windows user (as Antarctic Pilot says, you may not be) I also swear by XPORT for managing the com port/GPS combination...
OpenCPN now says I am sat in the conservatory in North Devon!
Now, hangover cure anyone?
Many thanks to all of you. It is Windows 7 and 9600 baud rate.
It was simple.
I turned the laptop on with the dongle plugged in.
It installed it on COM35.
I put COM35 as the GPS source.
Allan
