PaulRainbow
I have used a few of those Garmin under deck mounts, no problems.I need to move the GPS antenna from its current perch on the radar pole (scanner incoming, we bought the boat with a pole clearly designed to take more than a small antenna).
And will be adding an AIS transceiver ere long, so two GPS antennae to place.
If it's not a bad idea, and noting that Garmin state you can put the GPS antenna under a fibreglass deck, I was wondering about doing that and preventing clutter from the pushpit.
It must attenuate the signal a bit, but is it viable in practice? Or is it better to put up with the blighters being at eye height, photobombing a lovely anchorage view?
Function overrides form here, but if it doesn't matter, I'll take form!
I have two possible locations in mind - under the aft side deck beside the (quite high) coaming, or for more effort, in the hanging locker.
Anyone got any experience with any of this?
Many thanks.
I have fitted dozens of Emtrak AIS, most commonly behind the switch panels, under the side deck, never had an issue.
Fitted scores of chart plotters in all sorts of locations, no problems.
I have two plotter, VHFs and AIS on the flybridge, the VHF and AIS are under some pretty thick GRP, all work fine.
At the lower helm are two Android tablets, mounted in the main dash pod, with thick GRP directly above them, above that, a vinyl covered housing, about that is the saloon ceiling and finally, above that the flybridge floor. They work fine.
Also in the saloon, another tablet, a PC with a USB GPS puck (tucked in the bottom of the curtain track, beside a stainless window frame) and two phones.
I think you might be OK.
