Goodwin Sands
Capt Popeye
30 Sep 2011
Dawlish South Devon
all our boats at our club sink into the soft mud/ sand each tide nearly to the water line and each tide all float, this is over 100 boats each tide and all keel types, never seen one with any issue. All move about and rock away quite happily. There must be something else going on as I’m sure the reports cannot all be wrong
Hi there Mr D I am not meaning to be silly, but suggestthat your Club boats cannot be described as 'sink' into the soft mud, more like 'settle' into the soft mud ?
Its a bit like describing a Boat thats afloat as'sinking' because its 'taking on water' ; a boat thats 'taking on water' is just either leaking or its rain water, surely ?
Leighb
8 Aug 2007
Suffolk
Having just checked the chart on my iPad, it’s not quite as “hole shaped“ as I thought, but still a deeper anomaly in a relatively flat area. See below - “The Well” near Armada mark.
I have had a further look around the area, and notice that there are 3 or 4 other "holes" of similar depth near the Cork Ledge racing mark, NW of Cork Sand. You might think that tidal movement of sand and mud would fill these in but obviously not.
steve yates
16 Oct 2014
Benfleet, Essex/Keswick, Cumbria
Why have I never read cautionary tales about such dangers from Maurice Griffiths, Des Sleightholme, Charlie Stock and others from an earlier era when drying out on sandbanks was more common? Those writers did, by contrast, highlight the deadly dangers of being bashed on the sands by waves, the boat filling if a deep keeled boat were laid too far over, the wind rising or changing direction, being holed by debris or one's own anchor fluke, or getting neaped.
I am open to persuasion that there is some sort of danger to intact yachts from quicksand, but I've seen no evidence yet.
Probably as you mentioned, gales and storm weather, nowt to do with quicksand of the like. No one lands and dries out on a sandbank in a gale among breaking waves, therefore there is no action which puts them in a position to be buried in sand.
We all know how snowdrifts form, and we've all seen sand on a beach pile up along a groyne or similar before.
So surely it's a logical step to assume that a large vessel pinned on a sand bank, amid high waves and violent wave action, will act as a breakwater and allow the tons of sand being thrown around to quickly pile up against it, and quite foreseeabley cover most of it up. They probably reappear when there is a gale or from a different direction, and the sand is being dragged and blown away from the submerged boat.
Hallberg-Rassy
29 Oct 2020
But that would require the sandbank to be built up 10', 20' above HIGH tide to hide them. It doesn't happen, does it?
The other big difference is that groynes, let alone dry land, are all rooted on solid foundations, not a 100' of sand-water mix before solid chalk bedrock is felt.
Capt Popeye
30 Sep 2011
Dawlish South Devon
Hi would suggest that instead of the Sand being built up, it actually is swallowed up into a hole or void that appears or is formed inside the natural crafted sand the craft is overwhelmed by the sand filling the craft up as it sinks into the void so with the result that the craft is overwhelmed by the influx of wet sand and its sucked downwards beneath thenatural sand line or height ?
Some time later on, the reverse happens and the Craft is uplifted to the natural height of the sand but cannot float owing to being filled up with the sand ? perhaps
steve yates
16 Oct 2014
Damn, good point. Hadn't thought that through :)
Sooo, perhaps its the action of the retreating breaking wavesthat scour sand away from underneath the structure only to dump it back alongside it, and eventually over it as the wave action continues?
jimi
19 Dec 2001
St Neots
If you put a brick on a Sandy beach what happens to it?
tillergirl
5 Nov 2002
West Mersea
An example of scour I think:
Image18 by Roger Gaspar, on Flickr
That is a series of 'slices' progressively across the Little Sunk. The 'V' on the bottom two slices to the left is an old wreck marked on charts. The ratio height x width isn't to scale so the 'V' should be much flatter - but nevertheless there.
Leighb
8 Aug 2007
Suffolk
Is it possible to repost the right way up?
tillergirl
5 Nov 2002
West Mersea
Well....... yes and no. The profile is the right way up. Words? No. Well not quickly. I was practicing 'cutting the slices' ages ago and just recorded that quickly. I would have to reload all the data again from scratch so it would take 15 minutes. And SWMBO is cracking her whip.
Hallberg-Rassy
29 Oct 2020
I thought that was an underwater profile of the Sands and thought it was quite accurate.
Bricks? not sure of the point being made.
If it's Crosby Beach, not a lot. They've been there since WWII.
ApwDpH4mJlm96LTKemr7oiG42d_eahFCuEMYYOXqGFOj0dMUUyDHqVJYwU_KId-wM5jl55D65qPbk9JMa0rJZf6JVojxlCrm6MHMcHXdsHnzv9XCNLhl7CNe2O-FuO2Ei8oE3IB4MKCO6Ish
Tomahawk
5 Sep 2010
Where life is good
Which is what? 70 years? In geological time it doesn't even figure on super slow motion..\But look carefully and those bricks are disappearing fast. In another 50 years that bit of wall woill be half that size.
Hallberg-Rassy
29 Oct 2020
The sinking boats and sands don't fall into geology though. I think they call it geomorphology?
In all fairness, I think this was more what the poster above was thinking about. I don't think it's a good comparison though, because what we're talking about is when the entire Sands change into a morphing slurry among relatively powerful tides and flows, and ships disappear in a single tide or two.
There are, however, some sandy beaches that have disappeared overnight, and then reappeared perhaps years later.
ex-Gladys
29 Aug 2003
Colchester, Essex
There's a cove between Porthcurno and Land's End called Nanjizal, and that will be boulders one year and sand the next...
tillergirl
5 Nov 2002
West Mersea
Just flipped it in photoshop
Why? You turned it the wrong way up! It's the profile of the Sunk Sand! Black Deep to the left, Barrow Deep to the right. I thought the blue water was the clue. The profile is the right way up, it's just the words are upside. I can explain why but I was just trying to illustrate the scouring of a wreck and nothing else.
