superheat6k
The air intake for the heated air is via a return air grill in the access panel direct from the main cabin. The combustion air hose will pick up from the engine room below, via an existing hole where the diesel filler hose runs through. I have thought one and hard about this but do not see cold air in over the top of a main fuel tank being an issue.Wouldn’t it be a good idea to intake air from the cabin space?
Less risk if you have a silencer exhaust leak and recirculating air in effect could
Make it warm up quicker as the intake air temp rises?
Colhel - mine is a Chinese version.
The engine room on a power boat is very well ventilated anyway to allow for the massive air supply required for the engines, but there is no tight seal from the engine room to the cabin so the combustion air will create a very low pressure drop in the engine bay so at least some of the combustion air will come from the cabin recirc, so any smells will be drawn into rather than away from the heater combustion side.
